600v | on ElectriciansForums
  • Thread starter Tosh
  • Start date
  • Replies 7
  • Views 1K
Discuss 600v in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
T
Tosh
went to change a consumer yesterday,3 phase supply with the consumer fed off l3, removed the fuse n checked for voltage to be safe, was getting 600v with the fuse removed!!! replaced fuse and went back to 240v, any ideas??:confused:
are you saying that you got 600V on he consumers installation with Fuse removed or at the service head??
possibly your meter out of cal..???
It's not impossible to hit 600v I have seen a three phase supply get to not far short of that because an 11KV / 415V transformer was not auto tapping correctly
So there may be two faults!
Reply to 600v in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Yup will do exactly that when I'm back down there. Thanks for the help
OK for a simple load. What happens with (say) SMPS LED drivers ? I'd guess : Loads aren't perfectly balanced, especially during startup, so one...
