600x600 recessed lights.. Sensor? | on ElectriciansForums
Discuss 600x600 recessed lights.. Sensor? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
whether you need one sensor, multiple sensors, or integrated sensors on the fittings will depend on the location and use of the install amongst other things. If you are employed surely this question is best asked to the gaffer ?
Personally if that is the request I would specify 600mm modular lights with integral sensors, maybe even looking at a dali type linked system. But as said, surely your gaffer has specified the job for you ?
Assuming these are in different locations, otherwise a single occupancy sensor will suffice.
I wired two sensors in parallel once due to lights timing out in an office on one and not much movement
(well they are office workers lol)
With 2 sensors one each end movement of some kind was detected within the time out period so problem solved.
Thought about hiring Ricky Jervais to do his office dance, that would have kept the bu ggers going lol.
Reply to 600x600 recessed lights.. Sensor? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
That will work fine as long as the Pirs use relay switching, some don't.
seen a couple of your posts now and IMO you are trying to save money by doing the design and install yourself even though you have no...
