G
gpz900jim
Hi, I am doing a rewire at the moment. Adding all of the breakers up and dividing by 0.4, gives me a total load of 71a. I will be upgrading the meter tails to 25mm and the main earth to 16mm.. The main fuse is 60a. My questions are;1 how would I go about getting the main fuse uprated? or can I note on the EIC that the main fuse is too small and recommend that the customer gets it uprated ? 2 I need to change the tails from the main fuse up to the meter, and from the meter to the cu. Will the supplier have to come along and fit the meter tails and reseal, or shall I just cut the seal on the meter and just say there wasnt one there at all? There is currently no seal on the main fuse. I know what I should do, but is the real world different ie, what would you do??
