63amp extension lead | on ElectriciansForums
Discuss 63amp extension lead in the UK Electrical Forum area at ElectriciansForums.net
I
iamelectric
got a job to install a 63amp supply 3 phase commando socket , for a lighting show for an opening night , it was a metre from the D.B so i wired it in 16mm SY cable, i have now been asked to supply am extension cable for it , one male plug one female plug , about 25m long , i was thinking of using 10mm SY for it as its more manageable , but 10mm comes in at 61 amps ccc , is this ok as its an extension?
Why would you think that an extension lead can have a lower ccc than the OCPD protecting it?
^^^^ what do u mean i have already installed the socket
As in the 63A socket (and plug) of the extension cable you are creating?
In any case a different sort of regulations apply ... BS7909 and regulation 7.3.3 states:
Cables for use outdoors and in general use should be rubber insulated and
sheathed in accordance with BS 7919 (H07RN-F or equivalent), with a
voltage designation of not less than 450/750 V (heavy duty flexible, as
defined in BS 7540-1) and resistant to abrasion and water.
NOTE 2 Thermoplastic cables are not designed for use outdoors. For example,
cables known as ‘arctic blue’, ‘SY’ are thermoplastic and are not suitable for use
outdoors.
16mm 3 core H07-RNF ... nice n easy :)
Reply to 63amp extension lead in the UK Electrical Forum area at ElectriciansForums.net
They do a cy type with pur coating and it is even tougher but is shielded
It's a room where someone sleeps, so it's a bedroom. Minimum standards were set in the Parker Morris report in around 1963. Anything built after...
