Selena Francis
OK guys, I will give you as much info as poss so that you can offer advice:
I brought a second hand sauna, re-assembled it at home and wired the heater into 13a just to test it worked, which it did.
Ran a 6mm cable into a seperate RCD in our consumer unit - the heater kept tripping the GFI as soon as the unit was turned on. Upon the advice of an electrician we scrapped the heater and brought a new one.
Wired the new heater in (still 6kw) - same problem, the seller said this is an inherent problem with Sauna heaters and to replace the breaker with a 40a non GFI type, which we did.
A brief "Hallelujah" moment as everything seems fine, but sadly whenever the sauna starts to get warm, the main house RCD now trips.
Is this actually an inherrant fault with Sauna heaters? i did not expect a brand new heater to present the same fault, thus logic (of an electrical dumb----) dictates that maybe the fault present is in the wiring / earth itself. However this has been checked by an electrician and they say everything seems ok.
Hope you can all understand why i am baffled, annoyed and frustrated! lol
Any help or advice would be VERY much appreciated - i didn't buy the sauna to loo at it! ha ha :mickey:
