6kW single phase inverter | on ElectriciansForums
Discuss 6kW single phase inverter in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
st3ve
Any ideas for a single phase 6kW inverter. I have had Power-one Aurora suggested.
Any others you can name/ recommend?
Thanks for looking.
Steve.
Its an 8KW+ TIC system, with a DNO maximum of 6kW. The panels are on 2 roofs facing opposite directions - so need a dual MPPT also.
Each inverter would have to be set for the peak of each respective roof, whereas a single inverter can be spec'd for the combined outputs of the 2 roofs.
As the roofs face opposite ways these peaks occur at separate times. Hence a single is the better option.
Reply to 6kW single phase inverter in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
I really can't see a problem with it assuming there is a neutral there.
All of the information for MG stuff is freely available from Schneider
davesparks
