Hi guys just want to run this one past a few of you genius dudes out there. Is the following ok...?
32amp mcb > 6mm cable > socket in loft > x2 2.5 (1 leg to underfloor heating in bathroom 13amp & 1 to summer element 13 amp both fixed) the socket has a shower pump permanently plugged into it with a 5 amp fuse. All RCD protected.
Now I know the 2.5 should have a 20 amp MCB normally but is this ok because they are run in parallel from that socket? Ie there isn't a section in the circuit that is just 2.5 with all the current going through. Thanks guys.
