6mm main earth on tns | on ElectriciansForums
Discuss 6mm main earth on tns in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
A
aaelectric
Would you fail a property if it had a 6mm main earth with no visible damage to overheating?
Probably get shot down as Ive left green book at work, but Best Practice guide says.." inadequate cross section ........where conductor less than 6 mm or evidence of thermal damage." This would be code 2. So Im saying 6mm no thermal damage, Code3 Improvement recommended.
Reply to 6mm main earth on tns in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Any metalwork connected to the MET could rise in voltage compared to true earth under an open supply neutral fault (on TN-C-S), and that would...
Haha yes, it is. Must be a northern expression. Have a Google 😂
