I have been asked to do a consumer unit change on a park home, 2x30amp 1x15amp 1x5amp, the supply form the meter is only 6mm, I am aware there are different regs in regards to theses installation. 6mm seems undersized, Is this acceptable?
Discuss 6mm supply to park home in the Talk Electrician area at ElectriciansForums.net
as has been said...you need to know what they are being given top end....I have been asked to do a consumer unit change on a park home, 2x30amp 1x15amp 1x5amp, the supply form the meter is only 6mm, I am aware there are different regs in regards to theses installation. 6mm seems undersized, Is this acceptable?
Reply to 6mm supply to park home in the Talk Electrician area at ElectriciansForums.net
