cbw
Ok, C.U. Change,
60A main fuse 16mm tails, pme @ 6mm main earth and 6mm main bonding to gas and water.
I know the 6mm main earth needs upgrading by DNO to 16mm, however just need putting straight on the following....
1. I will upgrade the water main bond to 10mm, however the gas is a nightmare, can I leave it at 6mm? I know it should be 60% of main earth so in theory not but how 'naughty' is it to leave it???
2. Can I leave the tails at 16mm given the 60A fuse? (Fairly sure I can)
Fairly basic questions I know but adibatic equation does my head in!
