6X4 Garden Shed | on ElectriciansForums
Discuss 6X4 Garden Shed in the Electricians Chat - Off Topic Chat area at ElectriciansForums.net
G
Guest77
I have contacted a Scheme with regard to becomming a Part P Electrician, I have my 17th and My pat testing one day certificate, now a Scheme who I won't mention for legal reasons has suggested if I can produce a Certificate for an installion and I pay the 400 Sobs they will have me on board.
Okay my plan, I have bought a Garden shed, it is 6 ft by 4 ft and is 20 foot from my house, I intend to dig a 1 ft deep trench and install a 6mm2 twin and earth cable inside a water plastic waste pipe to protect it from a socket in my Kitchen to the shed. I will install a RCD fused switch spur in the Kitchen off a socket which is on the ring and connect the twin and earth from there.
I will disconnect the earth at the shed end and install a earth rod into the garden and convert to a TT system, inside the shed I intend to install one plastic double socket and then a switched spur with a 3 amp fuse for the light, I may plug a lawn mower into the socket. Now my intial thoughts are all will be fine, however there is a metal window in the shed, do I need to install a 10mm2 earth wire to bond this? I have been told yes and no by different friends, I need to get this right, thanks for your help, all comments are welcomed and I won't listen to any nasty posts, please be kind, I am new.
Buy paraffin light
buy petrol lawnmower
no fuss no muss! :grin:
Replace metal window with a piece of Perspex and wooden beads, also use crazy foam on ends of "duct" to keep the rodents out. I assume you have the T&E spare as 2.5 would be cheaper and actually make the lights brighter.
No need for the rcd fused spur, just use an extension lead with built in rcd.
Put lights on a 3Amp plug and plug that into extension.
If any more sockets are needed just buy another extension lead.
Remember 2 RCD's in series is bad so 2nd extension lead must not have RCD.
Hope this helps your cheque clear with the scam.
That's way over the top in regards to safety. Look at the standards of installation in India and Asia. Not too many get killed there do they?
Nuffin better to do then mate??? lol
Are you saying that the socket in the kitchen is a bit of a Bully when it comes to twin and earth cable, if so I should have a word with it Mike:grin:
We recently had an english technical sales rep over to look at a machine. When we were having our lunch, he was showing us photos of the different ****ries he had visited. Bahrain was particularly rough. There was a piece of flex stripped back and shoved into the pins of a socket. (amid a multitude of other things).
Reply to 6X4 Garden Shed in the Electricians Chat - Off Topic Chat area at ElectriciansForums.net
BTW, the LD at the house will be 1" to accommodate the 6/3 coming from the house. Will use a 1" to 3/4" adapter to neck down to the 3/4" conduit...
