7 day imerrsion timer | on ElectriciansForums
Discuss 7 day imerrsion timer in the Australia area at ElectriciansForums.net
R
rapidrich
hi just a quicky just got a seven day timer from screwfix and the wireing diagram isnt to good .......
it has live in/neutral/com/no there is a link between live in and com would i be correct in saying supply live to live in linked to common then the supply and load neutral together and the live out in no thanx
Sounds right to me, I'd have a 20amp double pole switch feeding it for isolation purposes, since it looks like the timer is only single pole.
If you post the make/model, we might be able to get the wiring instructions on the web so that we can double check.
Reply to 7 day imerrsion timer in the Australia area at ElectriciansForums.net
Hi How did you finish the wiring? Please tell us so future members with the same problem can find the answer. Many Thanks
How did it go?
