70mm SWA Cable Support | on ElectriciansForums
Discuss 70mm SWA Cable Support in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi Guys
I need to cleat a 70mm 4core SWA cable along a 180m run in a tunnel below a castle to a new plant room, does anyone know what cable manufacturers recommend for spacing of cleats?
Table 4A onsite guide.page113. 450mm horizontally 600mm vertically. Cables over 40mm then manufacturers recommendation. I expect you have already come to this
conclusion?
Yeah I've already check my OSG but I don't know any cable manufacturers to contact today, so was hoping someone might already have an idea on the manufacturers recommendations.
Reply to 70mm SWA Cable Support in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
See there is the problem. I can put back to way it was. Is it safe, in my opinion NO!! It's wasn't safe before the incident. No Fused Spur...
All the lamp post cutouts I've ever seen have a twin swa gland plate built in to the base.
loz2754
L
