E
entech
When carrying out the visual , there are a lot of these cables fitted with 13 amp 1652 fuses. Is the reason for this due to start up currents of appliances??.
.75 is good for around 6 amps i believe so 13 amp will not protect cable from overload. I guess the appliance would have some kind of internal fuse to protect cable in such instance.
Hope this is right as theres a lot of fails otherwise....
