C
craig
Hi folks,
Can anyone shed some light on this ? I have 5 amp sockets around a room switched from a 2 gang switch at the door. 1 switch for the center light, the other for the 5amp sockets. When the sockets are on theres 240v between L-N and L-E when i swich off theres 78v between L-N and L-E. At the centre light theres a 7 or 8 volts on showing on my Fluke. All the fittings are MK. Tried another room with the same set up and got about 31v at the 5amp sockets ? All the bonding is done, incomming gas and water.Loop tests are all ok. The circuits are all RCBO's. Its a joint box system for the lights. Why the voltage ???
Thanks in advance.
Thanks in advance.
