hi all
At a fault today on shower circuit.kept tripping main r.c.d.
the neutral and earth were melted together at the pull cord ,now they have a daughter who spends one hour in the shower which prob is the cause of the overheating!
after fixing the pull cord a put the shower on for about 5 min to show the tennant that all was good.
however when a went to put the pull cord back up the heat on the cables was pretty hot!!
so the ? is should i recommend that they buy a 8 kw shower as a know the 8.5 is just a bit over.re wiring is not an option. the shower is in 6mm and approx 12 metre run
