8 Gang Grid Switch relacement | Page 3 | on ElectriciansForums
Discuss 8 Gang Grid Switch relacement in the DIY Electrical Advice area at ElectriciansForums.net
The left and right screw spacing that fixes the grid yoke to the backbox will be standard. The Yokes will be specific to the brand of module you want to fit in them. They are not a universal fit.
Hi Andy 78,
Great - Many thanks.
It was only to see if the grid yolk centres would fit our back box. We are aware that different switches require different yolk grids.
Thanks again.
concur with andy. back boxes are standard. all that differs is the depth (front to back).
Generally they are standard, I think it is only one of the ridiculously expensive manufacturers that do something different, maybe Wandsworth or Forbes and Lomax.
That is a old MEM Delta grid I think that they are discontinued know and Delta are rebranded as Eaton now and the design has changed. Bearing in mind that all the engraving has gone you are better off getting a new complete grid switch I have always found MK to be a solid grid but for the lower end Deta or BG.
Reply to 8 Gang Grid Switch relacement in the DIY Electrical Advice area at ElectriciansForums.net
Double pole switches? Mounted on a grid module? Ignore the fact they have a N stamped on them. Or is your 2 gang switch decorative, and you...
I am living in the north of Thailand where the grid is very unreliable (rainy season outages multiple times per week or once a full week). I...
