Andy,
Maybe it would seem that way but my experience in the switchgear industry and testing of product in compliance with the standards gives me a unique view point which other mainly users may not be aware of. You will find alot of switchgear companies don't attack... and it was not my intention. As i said Benedikt have a good product, just not accepable under IEC with a padlock handle. It would be the same if K&N were to market their knife contact/snap latch switch in an enclosure with a padlock handle. we ourselves use ABB switches and others, you will find that Moeller buy our switches and ABB etc. Switchgear in effect is like a family generally good companies use the best products from their competitors aswell as their own.
I am not here in a K&N compacity but am happy to answer your question.
1. Arcing and welding happens on all switch types AC & DC regardless of the contact system and other design advantages. It is how quickly you can build up resistance to blow the arc out that helps you acheive higher ratings for the switchgear. It is not just how much voltage and current that determines the ratings but the speed of operation, thermal rating, contact gap, switch material, contact type, number of operations, utilization category for the load type etc etc...
2. There is not such thing as a true DC isolator.
3. I think it is better explained as this;
The KG switch range is like say a ford focus, the car was designed and built for safety and can be fitted with a diesel (say DC if you like) or petrol (say AC if you like) engine.
The KG range was design with the switch-disconnector standards IEC / BS EN 60947-1 & 3 in mind, and has been tested for various different utilization categories for AC and DC use (the same as any other manufacturer, but maybe due to design of a certain switch type it is advantageous to market the product for one voltage set instead of both).
If say 2 cars were tested for a 5 star ncap rating and both compiled (say in our example both would isolate 11A @ 500V, DC-21B) then that is it. Regardless of anything else both would isolate or say stop safely in a test.
4. "rapid handle operation" - why not? anyone working with DC knows speed is a major point in building up resistance to blow the arc out. Or combine this with arc shutes or magnets or other methods (the common method being series connecting of contacts) and you have a very good means of blowing out the arc. Really this is such a minor point and more of a helpful note. It doesn't have any impact on safety.
Regards
Jon
