85 degree thermostat for imersion heater | on ElectriciansForums
Discuss 85 degree thermostat for imersion heater in the UK Electrical Forum area at ElectriciansForums.net
from that link all i cna find is:
Without Cutout
Only suitable if you have secondary protection
  • Temp Range: - 10°C - 80°C
what does this mean by secondary protection?
Becuase 70 is too low to fill my bath up right, i need to have boiler on for an hour put 4minutes of hot in, have it on for another hour out 1min of cold in 3 min of hot then it is hot and full ish!, so it is much easier not to use thermostat at all, but then not good if i forget to turn off so 85 degree thermostat should be fine and i will get a timer also. An Electrician/plumber has hard a time believing this in the past but what can i say this is my real experience, maybe my hot water tank/boiler is too small for the size of my bath, or it is filled half with sand or something.
But i dont use hot water for anything else so there is no safety issue and 85 degree thermostat is safer than none at all.
So please if you can help me find one then great, otherwise dont worry about it!
Strange attitude to have when asking for help here, mayby if you look yourself first and then ask if the one you have found would work, you might get a bit more help
Where in the hot water cylinder is the immersion heater positioned? ie, top face, side near top, side near bottom? If in the top face, you might get a better result by checking that the immersion heater and thermostat are long enough to reach towards the bottom of the cylinder and are heating the bulk of the water, rather than just the top few inches.
Could be this is part of the problem, the heater enters in the top, and the thermostat is 11inchs and the boiler is about 32inch high. Idk how long the immersion heater is, not sure i want to start doing that myself.
Reply to 85 degree thermostat for imersion heater in the UK Electrical Forum area at ElectriciansForums.net
There is no reason for an item of fixed equipment to be on its own dedicated circuit just because it is fixed equipment. There may be other...
loz2754
L
This is an RSS feed of thread: Leaking cylinder around immersion heater Content of the thread: Hi. My hot water cylinder has a small leak. It's...
