90Vdc miniature circuit breaker installation | on ElectriciansForums
Discuss 90Vdc miniature circuit breaker installation in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
J
jinqwem
Hi, i am looking to install a double pole MCB , like the siemens one into a dc circuit which will have 30 A current and 90Vdc voltage passing,
anyone know how to connect the MCB ?
From the research i done, it seems that connecting them together like the pic is the common way. [ElectriciansForums.net] 90Vdc miniature circuit breaker installation
Hi Mate,
The question sounds so easy to answer I think we are all waiting for the punch line.
But every question deserves an answer so go on I'll bite,
if all you are looking to do is isolate the battery module from the Cpu with a DP Mcb then that's the way to do it.
Not CPU but PSU, power supply unit,
I intended to used the power supply unit with dc output 90Vdc to charge the battery module,
just that the concept of connecting mcb in negative leg of the circuit seem a bit odd to me...
thanks anyway...
Reply to 90Vdc miniature circuit breaker installation in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Check the clearance between the back panel and/or terminal cover that you've removed. Look for small burn marks.
Found the cause of the tripping…. Just jointed them through… all clear now. Removed the smoke detectors completely. They were due to be...
