1) A length of conductor has a resistance of 0.6 ohm. State the expected value of resistance of a similar conductor of
- The same length and twice the csa
- The same csa and half the length
- Twice the length and half the csa
2) State, apart from loose connections, three circumstances that would result in an increase in conductor resistance.
3) For a ring final circuit, state
- The reason why phase to neutral readings at each socket would increase towards the mid point of the ring then decrease again
4) To what IP code should the following comply?
- An intermediate barrier inside an enclosure
5) State why a test on an rcd must not be conducted before a loop impedance test
Scenario
A 15-year-old dry-powder coating factory is situated adjacent to an 11kV/415/240V Regional Electricity
Company substation. The earthing system is T.N-C-S with an external earth fault loop impedance (Ze) of
0.012Ω and a prospective fault current of 20 kA.
The dry-powder coating process involves cleaning metallic components in an acid bath, washing off with water
sprays, drying with hot air blowers, spraying with electrostatically charged powder and finally baking in a
tunnel oven.
The existing installation, which are all radial circuits, is wired with (p.v.c.) conductors in metal conduit and
trunking. Six new lighting circuits supplying high-bay 300W SON luminaires have been installed using a
similar wiring system to the existing installation. The new circuit breakers are fed from a metal clad
distribution board housing BS EN 60898 circuit breakers.
An inspection and test of the whole installation is to be carried out.
6) Describe how an insulation resistance test would be carried out on a the new lighting circuit
7) Explain why it would be appropriate to use BS3036 fuses in a distribution board at the origin of this installation
8)An enclosure has been constructed on site to house electrical equipment, which may be exposed to water.
State the IP codes to which an the enclosure must comply as a minimum requirement?
I'd like to see what others answer for these to verify my own answers because I have no answers only my own...
Scenario
tunnel oven.
