Took out a 6Kw shower, re routed 6.0mm cable to switched spur and ran 1.0mm to a pumped shower.
Is the overcurrent protective device for the modified circuit, the 32A 60898 breaker or the 3A fuse in spur?
Is the cable size the 6.0mm or the 1.0mm?
I am thinking it is the first in both cases but seems a bit ambiguous the way it is set out.
Cheers
Cheers
