A bit of help needed here! | on ElectriciansForums
Discuss A bit of help needed here! in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Goody
London
I am filling in an EIC for the electrical installation with a light & a socket circuit for the newly built “Out-house” (garage conversion) and I have used the existing link from the main DB.
At the main DB -> Ze = 0.10 Ω , PFC = 4.0 KA and R1+R2 of the 2.5 mm link cable from the main DB to the Out-house DB = 0.32 Ω
Should I now assume that Ze at the Out-house DB is 0.10+0.32 = 0.42 Ω?, if not, how do I calculate Zs for the Out-house lighting circuit whose R1+R2 = 0.42 Ω
Again on the EIC which “DB’s” details should I enter for “Main Switch or circuit-Breaker” and “DISTRIBUTION BOARD DETAILS” boxes? Please refer to the pictures. I think main DB's details are not relevant here.
Many thanks!
[ElectriciansForums.net] A bit of help needed here![ElectriciansForums.net] A bit of help needed here!
Hi Goody,
As you say the Ze or Zdb for your second DB is 0.42, your lighting circuit R1+R2 is also 0.42 (on this board ?) so I would say the Zs for this circuit is 0.84
Ze + (Rx1+Rx2) + (Ry1+Ry2) = Zs where x is the submain and y is the Final circuit of the second DB, if that makes sense
Reply to A bit of help needed here! in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Question 1 do you prefer buttered, salted or sweet salted? I'm guessing salty 😜 1. Auto range multimeter (used on mains before when testing the...
CONCLUSION (Couldn't see how to edit title) It was not belting it down with rain today, so lifted the manhole cover. The pump is about 2 metres...
2 3 4
6K
