this is a real life fault i came up against. without over-complicating the issue of the site, i'll try to explain just the electrical side. OK. 10mm SWA 3 core feed to a wiska box. no RCD protection. from the wiska box there are 2 6mm 3 core SWA branches.lets call them 1 and 2. with minimal loads on both branches i got L-N 217V. L-E 238V. now applying a 2.5kW load to branch 1, 175V L-N, still got 238V L-E. however, no volt drop apparent on branch 2 at the load end. so then i'm beginning to doubt my original thoughts of a high resistance N conductor in the 10mm. further investigation found the faults ( yes, more than one fault which gave rise to the problem). right. lets have your thoughts on this. TRAINEES ONLY FOR STARTERS.
