A friend had a new consumer unit fitted | on ElectriciansForums
Discuss A friend had a new consumer unit fitted in the UK Electrical Forum area at ElectriciansForums.net
Pat H
Ware Herts
I wasn't able to help as really busy but they were having a new kitchen installed. The fitter said they need a new ring main for the kitchen and so needed a new consumer unit.
Had a look the other day. No RCD protection as it trips on the old ring main. The guy recons its the supply at fault and a 2DB check is needed (I assume that's Ze!)
No paperwork. No test results.
But of course the fitter is a friend of a friend so they don't want to make a0 fuss. I'll pop round and find out what the issue is with the old ring main and take the opportunity to test the new circuit as well.
I should then be able to re-install the 2 RCDs and even provide some results.
Reply to A friend had a new consumer unit fitted in the UK Electrical Forum area at ElectriciansForums.net
thank you it really made me feel small, maybe i played it a bit thick, but as the one needing the work done i was cap in hand, will try another...
M
I meant EIC, No idea why I put EICR down, thanks for the clarification
