J
jaybhill
Hi I am unsure on the regs with this I have a 100a main fuse but need to run tails outside
in armoured cable into loft of extension I know that I need a kmf switch but I'm struggling to find a small 100 amp one (not enough room for the big wylex ones) can I use a Switch Fuse Moulded Single Pole & Neutral, with 80A HRC Fuse or does it need to be equal to the main service fuse ?
Thank you.
Thank you.
