Hi,
when calculating the min csa of main earth using the adiabatic what current value do you guys use?
Do you measure the PFC and use that, or do you calculate using 230V / Ze, or do you use the tables in BS7671?
Been reading up on it, and seems a bit of grey area on here!
Also would you go with a 0.1 sec or 5sec disconnection time for a BS 1361 man fuse?
