a little help and advice | on ElectriciansForums
Discuss a little help and advice in the UK Electrical Forum area at ElectriciansForums.net
P
Patto
hi all, i have my 204 exam soon just want a second opinion on my answers to the questions and any advice given would be great.Q1 why does the choke voltage and lamp voltage not add up to the supply voltage.A1 the voltages across the choke and tube do not add up to the supply volatge due to the choke being an inductor producing a back EMF causing the voltage to lead the current by 90 degrees, they are out of phase..Q2 explain the effect a capacitor has on the supply current of an inductive load.A2 A capacitor will cause the current to lead the voltage so by adding this into an inductive load it will bring the current closer to being in phase with the voltage, this is know as power factor correction.i will add phasor diagrams to the above on the day...as for Q1 im sure i can use a right angled triangle to show this but looking through my notes i cant find were we did it.
You may find this type of theory people have long forgotten, unless they are Sheldon Coopers of the world that have eidetic memories.
The working man normaly remembers the important theories and calculations due to his brain cells being killed by drinking too much alchol :)
Reply to a little help and advice in the UK Electrical Forum area at ElectriciansForums.net
As you have actually measured the cold resistance (R1 + Rn = 0.15) then you have the voltage drop at the expected current (60A) so you can compute...
