A little help | on ElectriciansForums
Discuss A little help in the UK Electrical Forum area at ElectriciansForums.net
Wiltshire
The control panel is erroring up over a missing neutral, but I can't see anywhere to connect it, help [ElectriciansForums.net] A little help[ElectriciansForums.net] A little help
I have enough cores on the cable as its 6 core yy but just need to know where the neutral connects to
From the pictures Its difficult to ascertain the feed from the load. I can't see an outgoing neutral, unless its the pink/mauve conductors. So I might assume that the machine is balanced 3-phase for 400v operation.
Does the machine require a neutral? It will certainly require a cpc, but there doesn't appear to have one supplied !
If a contactor coil was incorporated then that might be where a neutral is required. But then coils can be 400V
We don't even know what it is your working on, or what you was showing us!!!
Unfortunately we are not distance mind readers, we need as much information as can be given, to stand any chance of being able to help with a query....
RTFM the first rule of confusion ....learnt that yrs ago but not supprised you are confused as it isn't complying with marking or colour codes, ensure you tag your cables with N - L1 -L2 -L3 etc....
Reply to A little help in the UK Electrical Forum area at ElectriciansForums.net
If the batteries are charged and the house is taking little then the full production of the panels will be dumped into the grid. As you have set...
We’ve recently completed the first and second fix of a barn conversion that is off grid with solar PV, batteries and a back up generator. This...
