As above, do not use 6242Y or similar solid conductor 'twin and earth' cable; it is only suitable for permanently installed, immovable wiring. Ordinary 3183Y PVC circular flex is the usual choice for indoor domestic purposes.
Commercial 13A-rated extensions and appliances are normally fitted with 1.25mm² cable, which has a rating of 13A in free air. However, 1.25mm² flex is not widely available in shops. 1.5mm² is common, rated at 15A and is the largest cable that 13A plugs and trailing sockets are designed to accept. Extensions made with either of these two sizes of cable may be used for any purpose since the cable is of equal or higher rating than the plug.
The combined load of the TV and DVD player will not be more than a couple of amps, so in theory a smaller cable could be used. However, it would be reliant on the correct plug fuse being fitted for protection and could not be pressed into service for a higher load application, or might overheat if this was not observed. Personally, I detest under-rated extensions; life is too short to faff around with one cable rated at 10A vs. another rated at 13A. Any lead I make for any purpose is fully rated to 13A and I need not think about it any further. I recommend the same here.
TL, DR; 1.5mm² 3183Y circular PVC flex.
