Spudnik
Chaps,
A little input if you would.
Kitchen refit.
Imagine if you will, standard base units with worktop. Induction hob etc. No access from ceiling above.
Now, there are going to be no wall cupboards at all, but the extractor is one of these space age type things.
So, i need to get a supply to it, which i normally spur straight off the top of a socket at worktop height and mount it in the nearest cupboard.
My only option i can see is to run a switched spur, drop the cable below worktop level, along behind the units and then straight up the centre line of the hob up to the extractor.
Now i reckon this should be ok, but i would appreciate your thoughts.
Ta.
Kitchen refit.
Ta.
