A perodic testing question | on ElectriciansForums
Discuss A perodic testing question in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Dazza1212
HI I HAVE A PROBLEM OF WHAT I DONT KNOW 1, HOW TO ADRESS AND 2, IF MMY SOUTION IS CORRECT,
BASICALLY I HAVE 2 PME 3 PHASE SUPPLYS IN ONE SMALL BULIDING
FIRST ISSUE I HAVE CIRCUITS IN ONE ROOM WITH ARE SWITCHED FROM TWO SEPERTE ORIGINS
SECOND IS DO THE METS OF THE PME ORIGINS HAVE TO BE CONNECTED DIRECTY WITH APPORITE SIZED CABLE TO TAKE AWAY ANT EQUPOTENAIL DIFFERNCE AS THERE IS AS I HAVE 2 DIFFERENT ZE VALUES 0.03 DIFFERNCE
AM I RIGHT TO GIVE BOTH OF THESE A NUMBER 1 ON A PERODIC AND HOW WOULD YOU RESOLVE THIS
ANY COMMENTS WOULD BE VERY APPRICATED AS NIC NEVER ANSWERE THE ****** PHONE OR ARE NOT OPEN
REGARDS
dAZZA1212
[ElectriciansForums.net] A perodic testing question
Reply to A perodic testing question in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
FFS - popped it apart, found the same issue and thought I'd update... You guys were already there!
He is after the four options for 1 and 2 of the multiple choice exam, probably optimistic someone will know this. Your question 3 in incomplete to...
