a puzzler can anyone explain it ? | on ElectriciansForums
Discuss a puzzler can anyone explain it ? in the UK Electrical Forum area at ElectriciansForums.net
Island dweller lol
Was at a house tonight that has 15 GU10 led fittings with 1.2W lights.
They are in 3 rows of 5 the 2 outside rows are on together and switched from 1 end and work fine.
The middle row are 2 way switched but when switched off always have a slight glow !
Any one have any ideas why ? I have changed the bulbs around and nothing changes checked the
switches and they are all perfect but still only the middle row glow any ideas guys ?
I changed the bulbs to 1.3W ones tonight and it has stopped them glowing but I still cant explain
why the 1.2W ones glow and would like to find a reason for future reference ?
They were all from Wicks's except for the 1.3W's they were from B&Q just in case anyone else has
had similar problem.
Tel does it matter were you put the snubber or is it the end of line you put it
bit of trial and error. generally across the load just to leak away the induced voltage.
I have had the same issue at a job that I did a week or so ago.
I reported it to the supplier and as tel says it will only happen in the 2-way controlled areas and there is currently being developed an identical looking lamp that has a capacitor installed I believe that will cure the issue.
CEF are sorting it out for me and they have all of the information you will require.
Reply to a puzzler can anyone explain it ? in the UK Electrical Forum area at ElectriciansForums.net
Back to the Men's Shed today to complete the installation of the 4 LED battens in the attic. These were a joy to fit, having screwed the units to...
    • Winner
