Hi,
I am adding a single socket spurring off from the downstairs ring as a minor work for my assessment. The tails from the main fuse to the meter and again from the meter to the Henley block are 16 mm. A pair of 25 mm tails then connects to another Henley from which 16 mm tails feed the main CU with a single RCD and a small one for the loft circuits. Sorry I did not make a note of the main fuse rating.
Would the assessor raise any question about the main tails being 16 mm during assessment?
Cheers!
Cheers!
