a question | on ElectriciansForums
Discuss a question in the Australia area at ElectriciansForums.net
dingledong
if i can come of from a ring to one point i.e. a double socket . but not 2 singles . would you class a duel box as 1 point or 2
so could i come of of thre ring into a duel box ?
Im using imagination here but I suspect its to do with the CCC of the cable, which assuming is 2.5, then just follow the 'string' of cable and add up the 13's you'll see what does and doesnt make sense, tapping off a ring in 2.5 on 32a breaker!
Coming off the ring to a dual socket = 1 point
Coming off the ring to a dual box (two seperate connections) = 2 points (having said that a dual box for 2 x FCU's which are fused down should be allowed IMHO).
Tin hat on
Reply to a question in the Australia area at ElectriciansForums.net
none at all.... and the rcd trips within specification... test button operational.... nothing to suggest there's a problem until you take the...
Luckily when I rejigged the socket to fit the fcu next to it, it meant the original ring wiring reached, i put the socket on the ring and took a...
