A supplier with stocks of Strix R72 kettle switches? | on ElectriciansForums
Discuss A supplier with stocks of Strix R72 kettle switches? in the UK Electrical Forum area at ElectriciansForums.net
M
MarkieSparkie
I am having difficulty sourcing Strix R72 kettle switches. Does any member know of a supplier with a dozen switches in stock?
Reply to A supplier with stocks of Strix R72 kettle switches? in the UK Electrical Forum area at ElectriciansForums.net
Happens on every job of ours, houses are usually empty for a year or so and they are always £300-£400 in debt mostly due to the standing charge...
It often works for me 🤪
Hi, I need to rewire a mapping/traction control switch on a race bike that was damaged in a crash. The switch is not stock to install some other...
Where are you measuring the voltage when you say you are getting proper voltage at the base? If you are measuring at the tabs underneath the...
I have a recurring DC Interference fault on my solar system. I have gone through all the scenarios recommended by Solis, but still no solution...
