B
bmitie
Just found this great site, saved me a fortune!! Plumber was called to check heating problem, rads getting warm when HW on!! His solution, replace the drayton valve and actuator, drain system etc. I was not convinced so did a bit of reading, got to part, check spring on drayton, did that and... spring had broken loose!! re did it with a small screw, result, rads don't heat up anymore when HW is called for. After all my reading I now know I have a SUNVIC momo 2 port valve on the DHW and the DRAYTON spring return on the CH. And the sunvic model I have has a chequered history, szm 1801. To me it never worked properly eg switch off valve and boiler when hot tank reached required temperature, it may have always been faulty.
However, I digress, is it ok to have two different type of valves on an s plan system? I am still learning and checking what happens when I do various switching.
BMITIE
BMITIE
