About a ac small motor | on ElectriciansForums
Discuss About a ac small motor in the UK Electrical Forum area at ElectriciansForums.net
Los Angeles, CA
I have a small motor that I use to sharpen my kitchen knives, this has like a capacitor, is for 2 wires, but dont have signs where the blue wire go and where the red wire go, this motor starts and soon it stops, how to test it, i have 2 images,
[ElectriciansForums.net] About a ac small motor
If the motor starts normally, the capacitor is probably correctly connected but might be faulty and breaking down when subjected to working voltage. I would change it, 75% of the time this will solve the problem. Alternatively the motor may be cutting out because a thermal protector is switching it off, either because the capacitor is indeed faulty, or the motor windings are damaged and taking excessive current.
Reply to About a ac small motor in the UK Electrical Forum area at ElectriciansForums.net
I would agree that the motor is by far the best part to replace. if it is powered and not turning then it is broken. Keep it simple!
Hi James, At the inverter end the multi strand is ferruled and torqued in the terminal and at the motor end they are the “wago type” push fitting...
