ac/dc breakers | on ElectriciansForums
Discuss ac/dc breakers in the UK Electrical Forum area at ElectriciansForums.net
W
wolfiehogan
hi can some one tell me the main difference between dc and ac breakers.also is dc voltage more dangerous than ac.is this because dc voltage is constant. thanks
Some MCB's (breakers) are fine to work on DC as well as AC. You need to check the manufacturers specifications. DC can be equally dangerous as AC depending on the circumstances.
Reply to ac/dc breakers in the UK Electrical Forum area at ElectriciansForums.net
The fact it is 3 pole, suggests it is intended for 3ph ac. Most dc breakers are single or double pole. It only lists 50/60hz in its rating table...
Hi all, This may is a little odd and may take some getting your head around but here goes... I measured around half the load current on two DC...
