AC relay using light bulb to switch on/off ! will it work > | on ElectriciansForums
Discuss AC relay using light bulb to switch on/off ! will it work > in the UK Electrical Forum area at ElectriciansForums.net
P
paulwalldall
Hello. first post. hope in right section.
Farmer friend has a hen brooding pen. (large enclosed box with 240watt heat lamp) with one lamp. when lamp fails the chicks get cold and soon die which is sad but also costly in birds. thought there must be a failsafe device somewhere to turn on an alternate bulb but he says not.
Thought that wiring his one bulb in series with the coil of a 240v 16amp relay would work and when bulb fails, relay de-energised and goes to normally closed and switches a second reserve bulb on would do the trick. wired this up , switching reserve bulb on/off by removing and replacing first bulb works fine but first bulb will not light at all. anybody know why. current must be flowing through first bulb to energise relay but bulb wont light. tested all components individually and all ok. only thought is the coil has a resistance of 7kila ohms and the bulb only 260 ohms. measured over each bulb and coil and all read 240v when they should. am i being a bit rubbish or am i missing something fundamental. this was just a mock up at home so no dead birds yet but has anybody any ideas. or suggestions to achieve the ' one light fails and another comes on goal'
thanks Paul.
Use the same set up that you have now but change the 230V relay to a current sensing relay.
Remember this set up is only good as long as the lamp is changed ASAP after the first blows.
A photo cell would have the lamp flashing on and off like a disco light.
i meant to use a photocell to activate the alarm. the photocell reacting to the light, and activating the alarm when the light went out. probably require a relay.
Instead of an alarm/sounder i'd install an outside indication light (a red bulkhead fitting for example) that shines when the main bulb has gone out......main reason being a sounder going off might effect the birds and annoy any neighbours if the farmer was out when a failure happened (he would however see the exterior bulkhead alight)
Coil and relay coil in series, most of the voltage will be dropped across the relay coil, check that with a meter
Swap them round so the relay comes after the light. Make sure the light is lit before you drop the voltage across the coil. Simples! :D:D:D:D
Since there seems to be room for a second lamp could you use two 120W ( or 4 x 60W ) in parallel?
Thank god you said it, I was thinking it but didn't really have the cojones to say it through fear of seeming too simplistic. Surely this is the best solution? Maybe even go one step further and have the two/four lights on seperate circuits incase the overload caused by a bulb blowing trips the breaker then you still have three functioning.
Reply to AC relay using light bulb to switch on/off ! will it work > in the UK Electrical Forum area at ElectriciansForums.net
This contactor you suggested unfortunately only has two NO switches rather than 1 NC and 1 NO required for the CR3 current sensing bypass...
To be honest Markelect, You have had a good 25 years trouble free, I wouldn't waste any more time and effort and just go for a full replacement on...
