Acceleromoter | on ElectriciansForums
Discuss Acceleromoter in the Commercial Electrical Advice area at ElectriciansForums.net
Lc1
Anywhere
Hi
I have a question about accelerometers. Does anyone know of a company/supplier in the U.K. that supplies tri axis accelerometers that are wireless? Or even a bespoke unit that operates on radio telemetry?
Also a control unit is required which would be required to operate 2 trip signals when a set point is reached.
Every unit I have seen requires to be cabled but has anyone dealt with this kind of technology before?
If this is for an industrial, or an application for placing on the market, you will be better off buying an off the shelf solution, else you will spend so much on getting it CE marked and compliant that it will cost you more.
An off the shelf solution will be CE marked, compliant and reliable.
If it's DIY, then fill yer boots.
Reply to Acceleromoter in the Commercial Electrical Advice area at ElectriciansForums.net
Most RC Model systems work on a bus system now days so minimal wiring, Transmitters are available up too twenty channels and more so that is not...
My bafflement increases. I swapped the offending light with one elsewhere on the back of the house - one of those that's on a circuit of its own...
