Accenta Gen 4 issues | on ElectriciansForums
Discuss Accenta Gen 4 issues in the Australia area at ElectriciansForums.net
steq184
Please excuse the long story but feel I should give you the full story to make it easier to help me with the problems I am having.
I have an Accenta G4 with 2 remote lcd keypads. The system has the following zones wired:
1. Front hall pir
2. Rear hall pir
3. Living room pir
4. Back door contacts
5. Unused and set as unused.
6. Front door contacts
7 & 8 unused and set as unused.
* I have not wired in an external siren yet*
Have made sure all the fitted links to PA, Tamp and TA are fitted.
On powering up the alarm, the alarm sounds and I enter code 1234. to silence alarm. I put the cover on the panel.
On the keypad I get the error message Tamper Fault Lockout.
It does not recognise my 0123 factory set code and stays with the error message.
If I enter 9999 and go into engineer mode & go into walk test it sounds 2 tones an should show all the 8 zones as zeros until I activate it...zone 5, 7 and 8 are showing 1s already, also although the pirs led lights up it does not activate the walk test. The contact zones change when activated but no zones generate a tone at all.
The pirs I have are Guardall PQ15, I have wired as follows:
On pir + to 13v on panel.
On pir - to 0v on panel.
On pir NC alarm to zone on panel.
On pir NC tamper to TAMP on panel.
Any help would be greatly appreciated
this sounds like the panel needs resetting. follow the instructions for "restore factory defaults." also, and i'm not sure on this particular panel, as you have 2 keypads, you may have to add or remove a resistor to 1 of the keypads
This is a common problem with the Accenta LCD key pads - it will be a the spring in the back of one of them! Take the RKP cover off, stretch the spring a little (carefully) then as you put the cover back on you should hear the micro switch click
Thankyou very much.....the tamper fault lockout was indeed the little sprinf in one of the keypads.
The other problem I have is that when I go into engineer mode and select walk test all the zones should be set at zero until i do the walk around and activate them.......but they are showing 1s as if activated....apart from the front and read door contacts.
Any ideas???
Reply to Accenta Gen 4 issues in the Australia area at ElectriciansForums.net
Commonly known as double knock, some pirs have a latch on time delay for a few seconds, giving time for the 2nd one to activate .
