Accenta Ideal | on ElectriciansForums
Discuss Accenta Ideal in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
telectrix
Mentor
Nearly Esteemed
cheshire/staffordshire
anyone know if i can get a replacement (panel or PCB). the Ideal used ID biscuits in detectors so it needs to be either an Ideal or compatible.
Not sure about accenta replacement pcb but texecom does premier elite 60ixd expander that is designed for biscuits. It would need to be hooked to one of the texecom panels as well.
Reply to Accenta Ideal in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
A
Looking for a cradle (Ideal Standard)!! Hi All, I'm desperately looking for a cradle (the assembly that connects the flush unit to the cistern...
Audiotechnical
A
Ideal Standard Dual Flush Cistern Overflow Problem Any help greatly appreciated. It appears that every time i flush the toilet the cistern fills...
damobolton
