Acceptable Ze value for a TT System | on ElectriciansForums
Discuss Acceptable Ze value for a TT System in the Australia area at ElectriciansForums.net
smyler86
Hi All
Hope you are having a good day.
What is an acceptable Ze value for a TT system??
I know TNCS = 0.35 and TNS = 0.8.
Cheers
Dan
I didnt know that!
On a similar note, I was at a mates house (TT system) and they had the main earth electrode, but were they had bonded the gas supply, they installed a new earth electrode on its own (not connected to the MET)
I cant decide if this is ok, I am thinking no.
What do you guys think?
If you can see the Sydney Opera House youv'e gone to deep. :D:D;)
I didnt know that!
Sorry Smyler my jest came at the same time as your post, to answer your question I would say the two earth rods need to be cross connected to avoid a potential differance between the two:)
Reply to Acceptable Ze value for a TT System in the Australia area at ElectriciansForums.net
Generally speaking local earthing will rarely be below a couple of ohms, so in parallel with a TN-S sub-ohm value will make little difference...
Thanks I re tested this morning as I had other bits to finish off . I tested three times and it was 0.30 every time . It may have been my leads...
