Access control (cannot get access to main forum) | on ElectriciansForums
Discuss Access control (cannot get access to main forum) in the UK Electrical Forum area at ElectriciansForums.net
bigash
uk
Ok asking for some advice here.
On a job at the moment and an elderly couple have had someone out who seems well to me to of buggered the system due to wrong wiring at the relay.
The relay is set to be NO circuit.
At the moment the wiring is this everything in the diagram is correct and wired correctly.
From the door contractor (lock) we have one cable going to PGND and the other going to the - on the unlock module. They have then put a jumper cable between PWR and the other contactor, throwing the live over there.
[ElectriciansForums.net] Access control (cannot get access to main forum)
If I switch the system to NC the door entry buzzer works constantly. On the NO the relay does not work so the door does not open.
Now I don’t want to touch this until I am sure would removing the live jumper cable in totality, removing the Neutral from PGND and placing it on SGND, then the other cable putting it on the + side of the contacts, would this work? The lock is a bell 203.
Reply to Access control (cannot get access to main forum) in the UK Electrical Forum area at ElectriciansForums.net
This contactor you suggested unfortunately only has two NO switches rather than 1 NC and 1 NO required for the CR3 current sensing bypass...
By retired electrician, I mean that I have retained my ticket but no longer do installation work. Thanks for the clarification. I missed that it...
