Accuracy of test instrument | on ElectriciansForums
Discuss Accuracy of test instrument in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
L
lofty84
state three methods for checking the accuracy of test equiptment.
calibration
check box
check against someone elses meter
can you think of anymore ?
If an instrument is found to be inacurate after tests have been completed list three ations which should be taken
what would be your standard procedure for this ?
I would re check the meter and make sure the batterys are in good order. (Could be that simple especially if its a1552) as per manufacturers instructions.
Check the meter against another meter to see if the readings differ or check box / both.
Have the meter re calibrated repaired if still not accurate.
You would need to re test the previous things to make sure everything is in order.
You would normally have a rough idea of what the test results are giong to be so alarm bells should be ringing quickly.
Upvote 0
The last time I sent a Fluke to Dowding & Mills the company I worked for complained it would have been cheaper to buy a new one. D&M is where the company all sent all the instruments off the plant. Can’t do right for doing
Upvote 0
its accuracy was checked against calibrated equipment, its a just incase you drop your tester box, then you can check it against a bench mark, and previous tests, do you realy know how often your tester should be checked?
look it up and you might be suprised.
and yes i do have all my equipment calibrated, onsite calibration, are a good company.
but you was asking about diff methods and mine is one.
and dont forget a resistance value of 1 ohm will still be 1 ohm the next day ?
Lofty,check out IQ post, sounds good to me.
just because i made my own little resistance check box dont mean it aint any good, or would you rather pay someone to make you one. the NICEIC like that i had one even though it was a home made one, as not many sparks have a check box.
Upvote 0
Upvote 0
nice gadget Bradzz
what about send it of for calibration and re do tests, let people know about suspect results, let client know also
When test equipment is "tested for accuracy" its not "Calibrated" at all ? So why call it "calibration". Does anyone know exactly how modern testers are calibrated? I would assume a firmware tweek would be involved as there would appear to be nothing to physically adjust ( at least not in the stuff i've seen inside of?? Its one of these areas that makes me go MMMMMMM....
Upvote 0
Exactly my point.
Upvote 0
No takers then????????????
Come on all you "calibration" folk ... defend yourselves..............
Dont worry about being technical.. we can take it...
Upvote 0
Depends on the ambient temperature on both days as resistance varies with temperature. That is why you may get inconsistent readings when taking your meter from a cold van into a warm building as the meter acclimatises to the ambient temperature the test results will vary until the meter reaches ambient temperature
I just use a collection of resistors why pay ÂŁ's for a fancy box when pennies will buy you a handful of resistors that will do the same job
Upvote 0
Reply to Accuracy of test instrument in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
Ok, please be aware that I am a 'do-it-yourself-er,' so if this isn't the right place to be posting this thread, let me know where I should be...
The challenge that you have with this is that you've no confirmed start point. Because you have a lack of an EICR you don't actually know what...
Electrical Courses
