ACS800 Fault code | on ElectriciansForums
Discuss ACS800 Fault code in the Commercial Electrical Advice area at ElectriciansForums.net
My house
Hi all,
Had this fault on a few ACS800s
Some background for your own curiosity:
360KW submersible pump, on ACS800 with 2 paralleled inverter modules down to the pump basically.
"Line conv fault"
"Fault of line side of the converter" is the explanation, I've had it a few times on a few of our drives, but when i come to diagnose the fault the pump is down to earth. Which lead me to think why would it be the line side? Upon replacing the pump the drive runs a treat!
Anyone else had this fault before and what was your outcome?
Cheers
WS
Reply to ACS800 Fault code in the Commercial Electrical Advice area at ElectriciansForums.net
SOLVED Thanks for all the help. It was nothing to do with the smoke detector. In this new hole (where there will be a light fitting) three white...
I unmounted the intrument cluster and the pins was fine also everything OK with it.
