hello
customer has twin sky cables from dish to low level brush plate ,
he then has twin sky cables to high level brush plate , from low level brush
and finally a single sky cable from low brush to another room as a slave magic eye type outlet
i ran these cables in months ago , i got there today to find that he has sky HD running from the low level into decoder then from there VIA hdmi cable into the TV which is resting on the floor ,
my question is if the decoder stays on the low level is there a way of transmitting the HD signal via the two coax's buried in the wall into the TV once its mounted on the wall?
hope this makes sense
bes regards
bes regards
