puddn_joint
In my property I currently have one of these meters that has an isolator switch (use a flathead screwdriver to turn on/off)
I would like to add a Lewden enclosure with 100A isolator switch between this and the CU. Is this overkill and/or would cause confusion?
The reason I thought is that the screw turn seems a bit flimsy and is already a bit chewed up. Also in the future if a new meter is installed that doesn't have an isolator
- TL;DR
- Add an extra isolator switch to the one in the meter?
