Adding a new feed from a single light switch | on ElectriciansForums
Discuss Adding a new feed from a single light switch in the DIY Electrical Advice area at ElectriciansForums.net
halstead
I have a single wall switch powering 1 light and I want to add a separate light and change to wall switch to a double to power them both separel;y, how do i do this please?
You will need a neutral for the new light, also have you tested the switch for an effective earth?
I think you might need to employ an electrician.
Ok Thanks - I had hoped it would be fairly simple, but as its a little out of my comfort zone, ill take you advice.
Much appreciated.
Reactions: DPG
Rough age of house?
Modern homes tend to have a neutral at the switch, so it might turn out easier than you think.
Reply to Adding a new feed from a single light switch in the DIY Electrical Advice area at ElectriciansForums.net
"It works" and "it's safe" are not necessarily the same thing. With DIY work, they are often far from the same thing.
